Author Topic: '82 Toyota Pu 4x4  (Read 2955 times)
Offline scout254
'82 Toyota Pu 4x4
« on: March 25, 2012, 07:19:17 PM »
My brother is unemployed and needs to sell his truck...
http://www.pirate4x4.com/forum/showthread.php?t=1054664
1982 TOYOTA 4X4 SHORT BED
ASKING $2900 OBO
22RE CONVERSION with 1984 Toyota Celica 22RE Engine.
PLUS!! This conversion has been C.A.R.B. Certified (California Air Resources Board, certified)
Let’s be clear up front, the engine does have a blown head gasket. So it needs a new head,
as the old one has been machined past its useable life. The lower end is OK. New rings and Bearing awhile ago.
ABOUT THE TRUCK:
 22RE with Dual Row LCE Adjustable Camshaft Gear and Engine Builder Hi-Torque RV camshaft
 5 SPEED TRANSMISSION (Stock)
 DUAL TRANSFERCASE with MARLIN CRAWLER (Stock 2:28 Gears in both cases)
 MARLIN CRAWLER Low Profile SKID PLATE
 FRONT DIFF: 5:29 GEARS, OPEN
 REAR DIFF: 5:29 GEARS, DETROIT LOCKER
 35X12.50X15 PRO-COMP MUD TERRAINS
 15X 8 STEEL RIMS
 Recent NEW Front Windshield
 INSIDE ROLL-CAGE by SMITTYBUILT
 CUSTOM FRONT BUMPER with 8000lb WARN Winch
 CUSTOM ROCK SLIDERS (Built by Scout254)
 CUSTOM REAR BUMPER / SLIDERS with 6000lb WARN Winch (Built by Scout254)
 CUSTOM SHORTENED BED with SPARE TIRE MOUNT and JERRY CAN MOUNTS
 CUSTOM HEADACHE RACK with SHOVEL and HIGH LIFT JACK!
 ON BOARD AIR (by using an A/C Compressor)
 LIGHTS: PRO-COMP 130’s on front bumper
 ROCK LIGHTS and rear work/back-up lights
 STOCK STEERING
I HAVE THE FOLLOWING PARTS THAT WILL GO WITH THE TRUCK:
 Toyota 4" Drop Adjustable Drag Link
 Used early 22R Engine complete with engine stand (early 22R head, will not work on 22RE)
 3 doors – was going to fabricate some half-doors
 Leftover Transfer Case parts from the Dual Transfercase conversion
 5 Speed Manual Transmission (1982 Stock)
 Front Solid Axle Housing
 Stock birfields
 Front Knuckles and Spindle assembly with Rotors and Hubs
 Extra Tailgate
 Spare Stock Gas Tank (Had two tanks installed at one time)
 Heater Core Blower Assembly x2
 Bobbed Camper for the Custom Bed
I may have some other miscellaneous parts that I will throw in if the price is right.
(CB slide mount shown in photos is included, however the Jerry Cans and axe are not.)
TRUCK REGISTRATION IS CURRENTLY ON A NON-OP
TRUCK IS LOCATED NEAR GRASS VALLEY, CA
ASKING $2900 OBO AND IS BEING SOLD AS-IS.
CASH IN HAND TALKS!
SORRY, NO TRADES. I’m out of work and need the CASH
« Last Edit: March 25, 2012, 07:24:09 PM by scout254 »
