MY 1992 Jeep Cherokee has seen alot over the years. IT had a real easy life, i think, before I got it. I bought it with 103000 on the clock from a dealer in Redding. Paid way to much but it sutted my need at the time perfectly.
After it was paid off I started the mods. Now it is a money pit that gets me places, out seeing thing and into more troblem then one guy should be in. Yet the mods are not done. Currently I am in Stage 2. Stage 1 was a effort to have a balance between street ability and Off road capibilty. I found what I can " the happy middle ground" vary well. Stage 2 is just shy of a trailer queen. With only "minor" mods i want to keep the street ability just to get to the trailhead without getting pulled over along the way.
THE LIST
36" Super Swamper TSL Radials
K&N Drop In
PowerAid Throttle body spacer
Rubicon Express>
Front
7.5" front coils, Drop backets with supports, Adjustable upper control arms w/ Super-flex joint, 3" lower bumpstops, Extended uppper bumpstops, Fixed Lower control arm w/ Super-flex joint, Adjustable Track Bar with hiem joint end, Sway bar disconnects w/6" poles, Sway Bar Relocation Brackets, Stainless steels brakelines, Shock eyelet conversion
Rear
1.25 lift Shackle,Stainless steels brakelines,6* shims, ii inch resivior shocks
TSM MFG>
D44 rear disk brake converison
Rusty's Off road>
6" Leaf pack, 6" drop pitman arm, 1" blocks
Conferr>
Conferr Rack mate with custom floor
Bilstien>
Front 11 inch Resivior
ToysbyTory.com>
Alumi-Tie Rod
Dana 30 Diff gaurd
ARB>
Compressor with quick connect adaptor for tire hose
Air locker for D30 Front end
Air Locker for D44 Rear end
Stainless Steel Air lines for both front and back
Safari Snorkle
Garvin Wilderness>
Rear bumper w/ 2 d-rings, swing out tire carrier, Jerry can, axe/ shovel holder, High-Lift Jack, cb attenna mount
Custom Rear frame stiffener
Warn>
X8000i Winch
Rear diff gaurd
Strap
Wiggles>
Custom front driveshaft
High Angle Driveline>
Custom rear driveshaft
www.Rigidco.com>
FBW2 Front Bumper with frame stiffeners stuffed with Warn X8000I
Galaxay CB radio w K40 attenna
FlowKooler>
High Flow Water pump #1747
Robert Shaw>
190* thermostat High Flow
Rock-It>
High flow thermostat housing
Borla>
Headers
Cat back... both fully T301 Aircraft SS
Random Technology>
High Flow Cat.. shattered and hollowed
Boush>
Platium +4 spark plugs
Distrubitor cap
19Lb. Fuel injectors w/4 heads orginaly for a 5.0 Mustang- out for warrenty work
Select>
Orbital Gell battery
Borg Warner>
7MM Resistor Spark Plug Wires
Mean Green>
High Amp Alternator
Gear Reduction Starter out for warrenty work
XJARMOR>
Fan override
Rocky Road Outfitters>
Front & rear Bar pin Eliminators
Hesco>
Adjustable Fuel Regulator
MSD>
High Output Coil
H4 headlamps upgrade
Farmboy Desgins>
Rear Tail light housings
Custom LED package
Currie>
Steering box brace
Upgraded Aux fan from 97 XJ
4x4 Trail Hunter>
2"x4" slider replacement with extended tubing
Alloy USA>
D30 Axle Tube Seals
Cromo Rear Axle Shafts
Cromo Front Axle Shafts
Custom>
Rear bumpstop extentions w/ Daystar poly stop
Main fan removed and replaced with 14" Zirgo electric fan
Rear bulkhead stiffener
Advanced Adapters>
Slip Yoke Elimator in NP231
Tera Flex>
TeraLow 4:1 for NP231
and a ton more...
Things on order currently
Magnaflow Cataytic converter to replace blown Random cat
CSF 3 core radiator
