Author Topic: 2 hp outboard  (Read 5134 times)
Offline toyoder
2 hp outboard
« on: July 13, 2007, 07:28:09 AM »
great little light weight engine runs perfect ready to use $125
Offline toyoder
Re: 2 hp outboard
« Reply #1 on: July 13, 2007, 07:31:36 AM »
located in redding ca
Offline toyoder
Re: 2 hp outboard
« Reply #2 on: July 13, 2007, 11:02:58 AM »
sea king brand but not to old all plastic cover ect very light weight
Offline Sar 450
Re: 2 hp outboard
« Reply #3 on: July 19, 2007, 01:26:42 PM »
That is so cute. ;D
Offline toyoder
Re: 2 hp outboard
« Reply #4 on: July 19, 2007, 04:19:27 PM »
ya it is you should buy it  ;D you could mount it to your tail gate for those deep water crossings ;D
Re: 2 hp outboard
« Reply #5 on: July 20, 2007, 01:09:52 PM »
I'm interested.  Does the tank leak out if you lay it on its side while you transport it?  What is ECT?  Takes 50:1, right?  I want one for fishing late in the season when the wind blows my little boat around.
Offline toyoder
Re: 2 hp outboard
« Reply #6 on: July 20, 2007, 01:22:11 PM »
it has a shut of on the tank so if you ran the carb dry before transporting im sure it would be ok and not leak it does take 50 to 1 i believe it says on the fuel cap. ect is sea king abbreviation for electronic ignition (no points=solid state ignition ) its a good little engine very reliable just wasent enough power for our aluminum boat with all 3 of us in it ;D
Re: 2 hp outboard
« Reply #7 on: July 20, 2007, 01:34:43 PM »
Would it get me and my father-in-law across this lake to the fishing spot in our 12 ft jon boat in a snowstorm?
Offline toyoder
Re: 2 hp outboard
« Reply #8 on: July 20, 2007, 01:58:50 PM »
 your not going to pull a skier up but it will get the job done  ;D man that looks cold
Re: 2 hp outboard
« Reply #9 on: July 20, 2007, 02:02:51 PM »
Then its a deal.  You coming through Chico anytime soon?  How soon do you need it gone?
Offline toyoder
Re: 2 hp outboard
« Reply #10 on: July 20, 2007, 02:59:31 PM »
im not going that way till the weekend after next but i could bring it down then
